Results 1 to 10 of 35
Thread: returned and pool completely cloudy
    Default Re: returned and pool completely cloudy
    YEAH!!! Improvement!!! I can barely barely see the drain...but i can see it!!! the entire pool is still cloudy but improved! last night i added one pound of the ph decreaser as advised and 3 of the 3/4 bleach to bring back to 15.
    Results this morning...
    cl-12
    ta-180
    cya-50 (i didn't check again, but this is where it has been staying)
    ph- back up to 7.8 could be a little higher
    before i left for work, i added another pound of the ph decreaser and 2 of the 3/4 bleach to get back to 15. this is ultra beach that i have been adding.
    am i doing right?
    do i continue to hold it at 15 until it completely clears?
    do i continue to try to lower ph too if it continues to climb?
    please please advise. i am so thankful to each of you that is helping me!
    duraleigh Guest
    am i doing right?
    Yes
    "The solution to that is to keep adding Cl back up to those levels above over and over 'til the pool clears. A struggle for now, but you'll find it well worth the effort."
    Absolutely!
    Poolhelp, it would help you to reread many of the posts on the forum as well as the tips @ poolsolutions.com. You are certainly on the right track but do not seem to yet have a good grasp of where you need to be and why.
    (didn't mean to "shout" those answers...I'm experimenting )
    thank you for the reply and encouragement. and i didn't take it as you were shouting.
    i agree i don't have a good grasp on this yet, but i really am trying
    i have read and read the posts on this forum and i get confused sometimes with the responses. i'm not trying to offend anyone, i certainly appreciate everyone's advise and this forum. i think it is great and i am so thankful i found this forum. but sometimes when you read the posts i have seen different advise to some of the same questions i have and i get confused...so that's why i ask for myself to make sure i understand what to do. i hope you don't get frustrated with my repetitive questions. please bear with me as i learn and make sure i understand.
    can see the bottom of the pool much better this morning, still a way to go though. i know i must have patience and keep with the bleach and i am.
    i have a couple of questions though....
    ---i have been vacuuming and backwashing each day. now there isn't much debris there. there is some, but not much. my question is, do i backwash each day regardless until the water completely clears?
    ----with all the backwashing, i could stand to add some water. can i add now or do i need try and hold off until i get the water clear?
    thanks.
    Indiana.
    Quote Originally Posted by poolhelp101
    thanks.
    If you are still getting good flow through the filter, backwashing can probably wait. The filter will be a little better at getting small stuff out of the water when it's a little dirty. No reason not to add water unless your fill water has problems. Just be aware that your chemistry will change when you add, and keep an eye on it.
    Thank you John T.
    Now that you've got rid of the bloom and water is clearer, you should be able to get in pool and look underwater across pool and check to see how it looks.
    If you have your Cl levels maintained for some time but still have cloudiness, could be from small floating dead stuff your filter can't catch. Now is the time to get some clarifier and put it in. Probably best to mix in a container w/some pool water and then add it to pool. This will bind small particles together and sink them....then it's time to vac bottom! I was amazed how crystal clear this got my pool overnite. Some folks on the forum think it's a waste, and I thought so too until I tried it.
    Another thing that'll help your sand filter is a little DE added thru skimmer.
  1. Also in Louisiana, COMPLETELY new to pools
    By R6 Guy in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2012, 06:47 PM
  2. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  3. Problem removing algae completely
    By nancybram in forum Dealing with Algae & Slime
    Last Post: 07-17-2011, 06:47 PM
  4. completely confounded by air, prime problems
    By salinda in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 11:52 AM
