Results 1 to 10 of 26
Thread: I think I want to go salt.
Threaded View
  1. #14
    SJohnson is offline Registered+ Thread Analyst SJohnson 0
    Charleston, SC
    Default
    Wait a minute . . . You said that you have an inline chlorinator and you add granules every few days? You put trichlor tabs in the feeder and are dumping dichlor granules in the pool directly? Is that right? CYA levels are usually very stable so minimal draining and backwashing will not lower it all that much. Hmmm. Did you test the CYA or did a pool store test it? That kind of Dichlor your using is 56% chlorine whereas Trichlor is 90%. 1 lb of Dichlor should raise your chlorine level about 3 ppm, in summer heat, direct sun, every 3-4 days, that doesn't sound all that unreasonable . . . you're gonna love the Salt Cell . . . I'll bet.
    SJohnson
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
