Results 1 to 10 of 26
Thread: I think I want to go salt.
    SJohnson is offline Registered+ Thread Analyst SJohnson 0
    Charleston, SC
    Default
    How about you test your cya and post it, then everyone can give you some good, accurate advice . . .
    SJohnson
    hzz is offline Lifetime Member Thread Analyst hzz 1 star
    Toronto Canada
    Default
    Just to add to what Michael said...I also think a SWG will work for you....just be sure you oversize it for your situation.
    If you go for the Autopilot get the 60 cell....I got that one for my pool even though it is a bit of overkill.
    Default
    OK, let me be clear:
    It's not that the thread-starter cannot use an SWG--I would never say that or imply that. But if he is having a problem with his water, throwing money at it by adding expensive stuff probably won't solve it. You have to solve the problem first. There's no way around that.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
