Thread: Does 33 degree Pool Water affect testing results?
    Default Does 33 degree Pool Water affect testing results?
    Was wondering if extremely cold water affects our test results for chlorine and ph. I do not cover my pool and my water looks a tad cloudy. My CYA is maybe 10. Chlorine DPD drop test is 6 ppm. Ph is 7.5. TA is 110. No combined chlorine was detected when tested. Another question comes up too, do I need to use more chlorine to achieve the same results that I get in 80 degree water?
    Default Re: Does 33 degree Pool Water affect testing results?
    It will slow down the chemical reactions so you may need to wait longer, but it would just be better to warm up the water closer to room temperature before doing the test. The CYA test is most affected by temperature; the others not so much. Technically the pH will be higher at lower temperature, all else equal, so you generally want to measure pH at the actual pool water temperature (so that's an exception to the warm-up rule).
  1. Two months of Pool testing results on a new pool...
    By Usilpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2014, 04:33 PM
  2. Testing fill water - strange results
    By tado921 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2013, 10:57 AM
  3. 24ft Intex Above Ground Pool at 94 degree pool temp
    By Dusky203 in forum Pool Equipment & Operations
    Last Post: 06-25-2011, 11:47 AM
  4. Masters degree... but scared to maintain pool
    By Eyelovelabs in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2011, 10:57 AM
  5. Simple 15' AG Pool Water Testing Results
    By LennPrice in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2006, 04:02 PM
