Seeing as how my brother is a welder, can you post a pic of it for me to show him?Originally Posted by NWMNMom
I'll get some pix tomorrow. Modification made this afternoon to reel - 10'x3" pvc added to the center - washers welded at center and evenly at sides to mount/hold pvc - this was added to reduce the revolutions required to reel it up - Final reeled up blanket is "fatter" on the reel but then my arm isn't sore from cranking a dozen times to get the straps reeled in before the blanket!
I even thought of making one with an old ten speed or 5 speed bycycle gears so you could pick which ratio you wanted to reel it up. Example turn just a couple of turns of the crank which would turn the reel several times. or if got hard change gears and make it easier to turn the crank but less revolutions. Or just hook it up so it turns several revolutions but easy to turn. Oh the possibilites of gears. lol. But would take some time to build.
Aranon
Could you get some detailed pics?
Anyone have any pics or suggest a heavy duty solar reel that will last. Maybe a brand and model number. Please.
I have pix but can't post anymore here due to limits. I need to register with Photobucket or something so I can set a link...We are VERY happy with the reel he built, it worked just as it should yesterday when we got home from work and wanted a swim, reeled right up and pulled back out very nice when we were done.
YES its heavy and big, but then we aren't moving it anytime soon. Its not fancy or slick looking like the ones you buy, its very simple and the PVC pipe in the center is the only plastic, its there to bulk up/support the center, doesn't move so won't be breaking or bending. I suppose total cost was under $40-50 with the steel/iron pipes and Quickcrete being the highest items. Elbow grease has its own cost, but well worth it.
It looks pretty tidy back out of the way too - like I said before though, maybe 1-1.5' higher may have been nicer for preventing catching under rails - flipping/folding each of sides in 6-10" before reeling solves that.
Thank you Mom. Would love to see pics when you can post.
Aranon
