Thread: Pump start up noise
    Nov 2014
    Florida
    Default Re: Pump start up noise
    Thanks for the info. I have a pool and a connected spa with a pump for each. It is the pool pump that is making the noise. Guess I will have to check out where I can buy a replacement motor. Do you know if seven years is the normal life of such a unit?
    mas985's Avatar
    Pleasanton, CA
    Motors can last quite a while and 7 years is not uncommon. The biggest failure of bearings is due to a failed shaft seal which allows water to leak onto the bearing so it is important to fix the shaft seal at the first sign of a leak.
    Mark
  1. pump noise
    By aubratgyrl in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 08:53 PM
  2. Loud Pump Noise?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2007, 08:39 AM
  3. Pump noise
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 10-13-2006, 07:18 PM
  4. pump noise....
    By amyinraleigh in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2006, 05:19 PM
  5. Pump Noise
    By Piney in forum Pool Equipment & Operations
    Last Post: 06-11-2006, 11:52 PM
