Just bought a house with an inground pool. The pool is not in pristine condition. As best as I can tell it needs four things: 1) a liner, 2) cleaning, 3) patching of the vermiculite floor, 4) plugging of one of the returns, and 5) a section of wall replaced.
I feel fairly confident I can handle the cleaning, patching and plugging, and actually need to since I don't have the money to pay someone else to do it.
The liner will be installed professionally. What I am unsure of is how to do the wall repair.
This pool was built using what appears to be 1/2" pressure treated plywood as the wall. The pool has sat for 5+ years with no water and one of the walls has "caved in", meaning that dirt is pressing hard against the back of the wall and has popped the board out about 2-3". Popped with such pressure that the nail heads were actually pulled through the board itself all the way from top to bottom.
I don't believe the board can be reused, as it appears to be warped. And, I'm assuming that if I remove this board to replace it that the dirt behind it will rush forward and into the pool area. There is no option to dig the dirt out from behind as there is a 3' wide pool deck made of of 3" thick concrete above the wall, on top of which sets a screened enclosure.
How would one go about fixing this section of wall and how do I get the dirt back behind the new wood after I've installed it?
I've linked a few pics to help with the visualization. Thanks!
http://pho.to/7hOeK/i4
http://pho.to/7hOeK/5v
http://pho.to/7hOeK/ua
