Thread: Rapid pressure build up in cartridge filter
    Largo, Florida
    Default Re: Rapid pressure build up in cartridge filter
    Live algae will clog a filter quick. I bet that's what you've got, just not enough for you to see the algae yet.
    Test your water chemistry, preferably with a Taylor K-2006 or other FAS-DPD test kit. They can be purchased Post the test results here. If you have any algae starting to grow and chlorine in the water you will register combined chlorine on the test result. (Normally you would not expect to see any more than 0.5ppm CC) Here's a page on poolsolutions that tells you about he various test kits: http://www.poolsolutions.com/testkits.html
    The solution will be to shock your pool until you register less than .5ppm CC and you also lose less than 1ppm FC between sundown and sunup (night because sunlight breaks down chlorine).
    @Aaron -- FYI -- new members in the Getting Started section cannot follow links. (BTW -- Appreciate your help around here!)
    @JohnB -- You can get to the chart that Kelemvor was trying to link for you that explains the levels needed to shock a pool through this link: http://pool9.net/cl-cya/ (But, you will need to copy that link and then paste it into a browser window after you first log out.)
    Oct 2014
    I shocked the pool and maintained ~6-8 ppm FC with very little CC (per Leslie's test). FC does not change during the night. I frequently wash the filter cartridges but don't see anything coming off in the water besides a few small leaves. The pump flow is still very low even immediately after filter cleaning.
    Is there a better cleaning method than a water rinse? Do I need to acid wash them?
  1. high recirc pressure, Low filter pressure
    By cooter in forum Pool Equipment & Operations
    Last Post: 06-10-2014, 09:56 PM
  2. Rapid water loss after heavy rain
    By tpspeier in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2014, 03:29 PM
  3. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 07:54 AM
  4. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  5. hayward extreme cartridge filter-pressure gauge
    By t-cal in forum Pool Equipment & Operations
    Last Post: 05-30-2007, 06:14 PM
