Thread: Desire to run my pool cost effectively
    Oct 2014
    United States
    Default Desire to run my pool cost effectively
    I have been studying the BBB method and have started applying the principals. Currently my pool is full of algae from traveling and the frustration of not being able to depend on the pool guy. I have decided to take care of my oasis (pond) myself.
    My pool is 20'x40" in ground and vinyl. Sand Filter, Hayward Pump
    I have polaris pump PB4-60 that is leaking and is making grinding noise. I believe it may be the impeller or bearings. Are these pump easy to repair?
    Thanks,
    Conley
    Default Re: Desire to run my pool cost effectively
    Hi Conley and welcome!
    The key to the BBB method is good, solid testing. We always recommend the Taylor K-2006 or K-2006C test kit as the best, the gold standard but you can't buy it in stores, only online. Here's the link:
    http://www.poolsolutions.com/testkit-order-links.html
    If you get it, a good daily test kit is the K-1000 OTO/Phenol kit that only tests chlorine and pH.
    A more complete choice is usually only available at your local WalMart: The HTH 6-way Drop Test Kit. If you get this, be sure to pick up a gallon of steam-distilled water while you are at it.
    The HTH is an OTO kit that only measures total chlorine up to 5ppm. However, using "the Patented CarlD Shotglass Method" you can increase that range to 10, 15, 20, or even 25ppm. (the name's a gag, the method's real). Simply take a shot glass and a Pyrex measuring cup and put one shot of pool water and one shot of distilled water in the cup, mix, and measure THAT. Now whatever the OTO reading is, you can double it, up to 10. To get to 15, repeat the process but add 2 shots of distilled instead of 1. To get to 20, use 3 shots, and to 25, use 4. By that time, though it does get less accurate, but it WILL tide you over till you get the K-2006 and it's super-accurate FAS-DPD test.
    I can only guess at the volume of your pool, since it probably goes from 3.5' to 8' deep, and probably not as a simple ramp. So "best guess" is an average depth of 6' and that gives me a ballpark volume of 4800 cubic feet, or 35,900 gallons (7.48 gal/cubic foot). It's probably a bit less--below 35K but above 30K. For 35,000 gallons, each jug of 8.25% bleach (they come in 121 ounce jugs, not 128 ounce gallon jugs) will add about 2.3ppm of chlorine to your pool. Depending on the level of stabilizer, aka, CYA for Cyanuric Acid, you may need to maintain a level anywhere from 10 to 25ppm of chlorine to kill the algae. The stabilizer level determines that. Too little and it doesn't kill the algae. Too much and you risk bleaching or even damaging your liner. Bleaching is far more likely. If it's an old liner, you may not care about that.
    Not the pump expert but leaking usually means the pump-to-motor seal is damaged. Grinding noise means the motor's bearings are probably shot. If you are really mechanically inclined you can fix it, but you'll need a bearing puller to get the bearings off.
    Oct 2014
    United States
    Carl,
    Thank you. That was very helpful. I have my kit on the way and using test strips until it gets here. My liner is bleached due to a miscommunication between my pool guy and his son who took over his business, so I guess I have my own little personal sandbox to play with for winter.
    I will keep you posted.
    Thanks again,
    Conley
  1. Cost of pool resurface
    By donburks in forum In-Ground Pool Construction and Repair
    Last Post: 11-09-2013, 12:32 PM
  2. Replaster IG Pool Cost?
    By nickb1007 in forum In-Ground Pool Construction and Repair
    Last Post: 10-21-2013, 02:25 PM
  3. What kind of pool did you get and what did it cost?
    By Derek O in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2013, 12:50 AM
  4. In Ground Pool Cost - Which Cost the Most?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 05:31 PM
  5. Cost to heat pool.
    By gordonhyde in forum Pool Equipment & Operations
    Last Post: 07-11-2006, 10:59 PM
