Me, too.
Me, three!
36'x20' Freeform, IG - 13k gal, Spa - 800 gal, Diamond Brite, Intelliflo VS pump, TR-140C sand filter, Mastertemp 400k BTU heater, 2HP Whisperflo pump (waterfall), Pool Pilot Digital RC-42 SWCG, K-2006 Test Kit
Whoops! Just noticed I put this in the wrong thread. Ugh.
Normally in areas where you get a hard freeze people "close" their pool. This involves removing the water from the pipes so that busted pipes is a non issue. Unless you have a generator/UPS for the pool pump, relying on it running all winter is probably a bad idea. One power outage and you might have busted pipes.
Here's information on how to close a pool. You can also hire a pool guy to do it for you if you'd rather not DIY.
Thanks for the input. We are closing our pool down for the winter...but not our spa. Discussed this with the builder and he says that he's done this before. With the equipment and exposed piping inside the equipment building, and it being insulated, we should be ok. I hope. If worse comes to worse and it gets super cold, I'll put a small portable heater in there to keep things above freezing. Guess we'll see in a few months.
You are outta my league here on any advise, Toy... But I sure hope it works out. A spa post-close and pre-open sounds wonderful! I SO wish we had some kind, any kind of spa!!! So jealous!
