Results 1 to 10 of 109
Thread: Salt Water Chlorine Generator for New Pool Build
    Parker, CO
    Default Re: Salt Water Chlorine Generator for New Pool Build
    Quote Originally Posted by JimK View Post
    I just posted this in your filter thread and realized I should post it here:
    Like yours, the Aqua Rite has different cell size options that can be used with the same control unit. I believe the three options are 15k gal, 25k gal, and 40k gal.
    IMO, while the 25k gal size would probably work fine for a 16k gal pool (though I don't know how the spa impacts this) the 40k gal size cell would offer the best value as it would last the longest.
    Toy builder, though I only have first hand experience with the Aqua Rite, I'd have no problem recommending either brand based on what I've read.
    Thanks JimK. Do you know the difference between the AquaRite and T-Cell? Seem to me like they're the same thing. Also, they have another AquaRite model that plugs into a standard (GFCI) plug. No hardwiring required. This must be something new since I can't seem to find any reviews on it.
    I think we're going to go with the 40k model...from someone. Heck, already have the largest sand filter available why not go with the largest SWCG available.
    Virginia
    Quote Originally Posted by Toybuilder View Post
    Yeah, it looks like the AQR15-120 is a new model.
    I also just noticed they list an extended life cell (T-Cell 15LL). Hmmm...that must be new as well.....can't find any other info on it other than what's on the Hayward spec sheet. I wonder if it is compatible with my control unit. A longer life cell could mean lower cost in the long run.
    Autopilots can combine different controllers and cells, not necessarily a package. My thinking on that is look to get the controller that not only does everything you need it to do now, but will do everything you can imagine needing it to do in the future, then matching it with the cell you need/should have now ("now" being the next 5 years).
    Parker, CO
    Can you elaborate a little on the controller and what you mean by "a package". I've been on the the Autopilot website for about an hour now trying to figure out what I will need for our setup. By controller do you mean the Pool Pilot Digital? Do you have to have that? Seem like the manifoold is a separate item you need to puchase. Can you just use the manifold?
    You really need to talk to an expert on this. The Controller is the power supply and programming box. Auto Pilot makes more than one. The manifold is simply (in short) plumbing to hold the salt cell and must have a PS and controller. I have the 75003 controller. There are others.
    Parker, CO
    Guess I'm going to have to dig a little deeper. The builder isn't familiar with the AutoPilot either, so I may pass on this one. It may be out of my price range anyway if you have to purchase the both the Pool Pilot and the Manifold.
    autopilot.com may be of some help. They have dealers all over.
    Parker, CO
    Well, I’m pretty disappointed in Hayward’s customer service. I contacted their customer support this morning hoping to get a comparison from their side between the AquaRite and the AutoPilot as Poolsean had done.
    The rep told me to contact my local retailer which I did using their “finder” on their website. I wasn't satisfied with the locals answers, so I emailed him back to ask for a reputable online dealer or a sales rep that would know the ins and outs of the AquaRite. The reply I got was insulting. He emailed back with a link to the “finder”. I wanted to send back a reply telling him that I went with the AutoPilot because of his lack of service.
    Unfortunately, I think we’ll be going with the AquaRite. Not that I think the Hayward is an bad product, I'm just not happy with their service. However, if in 4 maybe 5 years and the cell dies, can I re-plumb to fit the AutoPilot? Would the wiring be any different? Do I know what I’m talking about? No. But, I’m hoping you or maybe CarlD would?
    Sep 2014
    Tucson, AZ
    I believe you said you were going with the Pentair IntelliTouch control panel. The IntelliTouch can be wired to run the AutoPilot if you decided to switch to AutoPilot. The IntelliTouch is fairly versatile as it can interface with lots of SWG cells. The pin-outs for wiring the various cells is in the IntelliTouch Installation manual.
    As for plumbing modification, not totally sure on that front. You'd have to download the different installation manuals for each cell you're considering and take a look at the various plumbing diagrams to know how much clearance you need for each. Some have specific requirements, for example, the Pentair IC40 says it requires a minimum of a 12-in straight run of pipe BEFORE the cell so that the flow sensor is not thrown off by turbulence from a pipe bend. Whether or not that is absolutely true is a bit debatable, but if the installation manual says it, then it's probably best to follow what they ask for unless your equipment pad is too crowded to comply.
    I feel for you! When we were going through our pool build, my PB liked to use all Pentair equipment but I asked him for information on other suppliers and products. He complied and gave me his pro's/con's list for each and what he liked and disliked and then I spent a good solid week's worth of late nights trying to sift through all the literature online. I eventually went all Pentair because I really couldn't parse all the nuances (and I was not a PF member at the time) and my PB is a good guy so I trusted his instinct and preference. So far, my equipment has been running just fine. I hope your search goes well!
    Virginia
    Given your experience with Hayward's customer service I'm surprised you're still going with the Aqua Rite. Is it just a question of price?
    It would be pretty expensive to go with the Aqua Rite then switch to the Autopilot in a few years. I'd go with the one you're more comfortable with from the start, even if it cost a bit more up front.
    In my case I didn't do any research comparing the two. I went with a pool builder I liked best, who happened to include the Aqua Rite instead of the Autopilot.
    I have contacted tech support a couple times and was happy with the service, but that was some years ago. I'm not sure if that was when Aqua Rite was under Goldline or Hayward.
  1. Problems with SWCG (salt water chlorine generator) on inground pool
    By jdubose in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2014, 09:16 AM
  2. Replies: 8
    Last Post: 04-09-2012, 04:37 PM
  3. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 07:05 PM
  4. Salt Water Chlorine Generator
    By blonde_b_tan in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 01:34 PM
