Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
Thread: Sodium Hydrogen Chloride OH NOES!!
    mwsmith2's Avatar
    mwsmith2 is offline Registered+ Whizbang Spinner mwsmith2 3 stars mwsmith2 3 stars mwsmith2 3 stars
    Katy, TX
    Default Sodium Hydrogen Chloride OH NOES!!
    Interesting story I just read here:
    http://www.click2houston.com/news/9349489/detail.html
    Sodium hydrogen chloride? Erm, methinks someone got the quote wrong. Two metals are generally not part of a compound. More likely Sodium Hypochlorite....in other words, BLEACH.
    What's the world coming to?
    Michael
    waterbear's Avatar
    waterbear is offline --trial user-- Sniggle Mechanic waterbear 4 stars waterbear 4 stars waterbear 4 stars waterbear 4 stars
    St. Augustine, Fl
    Default Re: Sodium Hydrogen Chloride OH NOES!!
    Well, there are other possibilities:
    Hydgogen chloride (muriatic acid)
    Sodium Hydrogen carbonate (baking soda)
    Sodium Chloride (salt)
    Sodium Hydrogen Sulfate (sodium bisulfate or dry acid)
    all of these are normal pool chemicals but I guess if the pH is too low from either muriatic acid or dry acid it might show up as an itchy feeling, Then again, so could too much chlorine I guess.
    11.75'x23.75' kidney 6.5K gal IG fiberglass pool/300 gal acrylic spillover spa combo; Aqualogic automation/SWCG; Pentair Clean and Clear 150 cart filter; 1.5 hp uprated 2 spd Pentair Whisperflo pump; PF:17
    mwsmith2's Avatar
    Katy, TX
    Yeah, I thought about those, but none seemed to add up to an itchy feeling like hitting the spa with too much Cl. Definately a non-standard compound name they came up with.
    Michael
    waterbear's Avatar
    St. Augustine, Fl
    well, what else can you expect from a jounalist trying to make up, er, I mean get a story for the news!
    waste is offline --trial user-- Whizbang Spinner waste 3 stars waste 3 stars waste 3 stars
    Talking Re: Sodium Hydrogen Chloride OH NOES!!
    At least they weren't exposed to dihydrogenmonoxide!!!!
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by waste
    So true! If that stuff gets into your lungs while you are in your pool it can kill you!
    haze_1956 is offline ** No working email address ** Weir Watcher haze_1956 0
    nj, usa.
    I just found out my pool contains huge amounts of dihydrogenmonoxide, At this point I am totally unsure as to how to deal with it. I was told the amount will decrease on very hot days. Anyone know if that is true?
    Orlando, FL
    haze, you need to get your DHMO levels down NOW. Immediately drain the pool, and re-test. You want readings somewhere in the 20% range. This is a common mistake (having too much DHMO). It is a very nasty substance with all sorts of evil uses. Make sure to tell the folks you meet in the pool stores about its dangers!!
    Indiana.
    Quote Originally Posted by waterbear
    My PS234 doesn't test for dihydrogenmonoxide. How can I find out if this stuff is in my pool or if it is at a safe level?
    duraleigh Guest
    This very dangerous condition is seldom discussed on the forum but, fortunately, Ben's kit will test for it.
    1. Fill the large comparator tube to the 25ml mark with pool water
    2. Add 4 drops of distilled water and swirl to mix
    3. If your sample turns blue, green, red, or chartreuse.....you're safe.
    4. If your sample stays clear you have a very bad case of it and you should immediately take cygnusecks advice and drain your pool.
    I have heard that a large magnet placed in the pool will help in this clearing process, but only for Libras and Scorpios. VOLDADDY, do not use your new waterproof phone near the pool if you install the magnet.
  1. Calcium chloride and sodium hydrogen carbonate
    By Rkh3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2011, 09:43 PM
  2. Liquidator and the sodium chloride deposits at the bottom
    By Water_man in forum The China Shop
    Last Post: 06-16-2008, 02:12 PM
  3. Is sodium bicarbonate same as sodium carbonate?
    By mshumack in forum Dealing with Alkalinity and Calcium
    Last Post: 09-18-2006, 08:52 PM
  4. Any Use for Hydrogen Peroxide
    By Sprint54 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2006, 08:28 AM
  5. Adding sodium bicarbonate AND calcium chloride at the same time
    By thr56 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 03:03 AM
