Results 1 to 10 of 19
Thread: AG Pool Closing with High CYA
    Jul 2013
    Northern Illinois
    Default Re: AG Pool Closing with High CYA
    Perfect! Yea, sometimes things get combobbled on threads. Good luck!
    A piece of advice, open early. When you think the water temperature may be close to 60 degrees, open. Take a full set of readings and post them. We will especially want to see your new CYA reading.
    You are not a subscriber, so unless you update that, you may have to wait for an answer on recommendations. If so, raise your FC right away and use your best judgement on the rest. Better yet, become a subscriber! You can go to the settings tab, then my account, then subscriptions. A minimum of 14 bucks gets you priority attention.
    Oct 2013
    Rhode Island
    Okay, I opened the pool yesterday. Here are the readings:
    FC: 3.2 ppm
    CC: 0 ppm
    pH: 7.8
    TA: 120 ppm
    CH: 60 ppm
    CYA: 45 ppm
    The CYA is down mostly to the fact that I had about a 50% water loss over the winter (heavy snow & ice load) and replaced with tap water.
    Sharkline Escalade RTR 24' x 54" Round AGP; OptiFlo 2-speed pump; Pentair PLM-100 Cartridge Filter; Hayward 250FDN Heater; Taylor K-2006; AquaIlluminator Return
    Jul 2013
    Northern Illinois
    How does the water look?
    Oct 2013
    Rhode Island
    It looks crystal clear! No signs of algae or anything.
    Jul 2013
    Northern Illinois
    Excellent. May I assume you raised that FC to the high-end of your FC/CYA ratio? Like about 6?
    Oct 2013
    Rhode Island
    I haven't added anything to the pool since opening. I was going to let the filter run for a couple of days, which it has now. As soon as I buy some bleach, I'll raise the FC, but should I raise it to shock levels (15) or max (6) or something else?
    BTW, thank you for all your help!
    Jul 2013
    Northern Illinois
    Well, see what your levels are. If FC is within your range for your CYA, you have CC<0.5, and your water is clear, you can just go with your maintenance range. Some people on opening like to do a test overnight to see if they lose FC.
    We are all happy to help!
  1. Closing pool, algaecide added and PH level real high now
    By tdurban in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-02-2013, 01:06 PM
  2. High CYA, so keep FC high, so are my high PH readings, falsely reading high ?
    By tdurban in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2013, 10:46 AM
  3. First Time Pool Owner Battling with Cloudy Water, High CC, High Ammonia!
    By yekalri in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2013, 06:48 PM
  4. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 03:36 PM
  5. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 09:50 PM
