Thread: Newbie.. Want to get some support for pool heater
    Oct 2014
    Saratoga, CA
    Default Newbie.. Want to get some support for pool heater
    Planning to relocate the pool heater closer to the side of the house, got 4 feet clearance from the window opennings, I do have a crawl space vent close to the desire location (1 feet away from the heater exhaust), is that ok? The crawl space vent is not for furnace air intake. I have a external combo air-con/heater sitting far away from the pool heater. Thanks for the feedback!
    Default Re: Newbie.. Want to get some support for pool heater
    I am no expert on pool heaters (non-solar), but an exhaust near a crawlspace vent sounds like a deadly dangerous code-violating idea that could spread deadly carbon monoxide through your house. Crawl spaces are not hermetically sealed off from the house (I duck-walked through many as a young carpenter...when I was still young!).
    Is it possible to run an exhaust vent from the heater to a safe location that meets code?
  1. Adding support to an Intext steel frame pool installed on un-level ground
    By jimevans_2000 in forum Intex-type Pool Setup & Operations
    Last Post: 06-25-2014, 10:16 AM
  2. Under liner support straps
    By hoover460 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-13-2014, 01:27 AM
  3. ground support for the u bars(supports) on intex ultra frame pool
    By rmills in forum Intex-type Pool Setup & Operations
    Last Post: 03-19-2014, 02:52 PM
  4. Autopilot and Poolsean support Awesome!!
    By gkosin1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2007, 11:52 PM
  5. Winter cover AG Oval Pool with Support poles and cable
    By johnnyf0614 in forum Pool Equipment & Operations
    Last Post: 06-16-2006, 02:45 PM
