Thread: jandy flopro pump making loud grinding noise
    Oct 2014
    Default jandy flopro pump making loud grinding noise
    Yesterday my system turned on - and a couple hours later I heard a loud grinding noise. I went to look and somehow water was pouring out of several of my pipes near the unit (resolved this). The pool level had dropped tremendously - once I refilled the pool, the pump is still operating but making horrible noise. Cause?
    Default Re: jandy flopro pump making loud grinding noise
    Hi,
    I'd guess either your pump section is trashed, or the motor's bearings are shot....but that's just a wild guess.
    Oct 2014
    My guess as well, probably bearings - instead of pulling the motor apart I opted to order a new pump. Thanks Carl!!! I ordered a Jandy Stealth 2.0.2 - hopefully it does save 20% off electric bill!
  1. Newbie here - Vinyl pool, Letro Jet Vac, and booster pump grinding noise
    By searayrules in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-29-2014, 10:57 AM
  2. Jandy Stealth Pump Making Loud Noises
    By Pahonex in forum Pool Equipment & Operations
    Last Post: 03-31-2014, 08:56 AM
  3. Pool Pump Makes Strange/Loud Noise
    By PoolKid in forum Pool Equipment & Operations
    Last Post: 06-26-2013, 09:40 AM
  4. Pump making loud buzzing noise
    By Islander2C in forum Pool Equipment & Operations
    Last Post: 06-18-2007, 09:41 AM
  5. Loud Pump Noise?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2007, 08:39 AM
