Thread: Pool/Spa Combo - Heater Installation - HELP PLEASE!
    Oct 2014
    Default Pool/Spa Combo - Heater Installation - HELP PLEASE!
    Hello!
    I've just moved in to a house with a beautiful Pool/Spa heater combo, the only issue is of course, it has no heater. Which it seems obvious that at one point it obviously did (or else that would be one useless spa), but there isn't one there anymore. I'll, be asking a few questions and posting a few pictures to correspond. Excuse my ignorance with terminology, this isn't exactly my forte.
    To start off, here is an overview of the setup:
    Pretty much, there are two lines into the system it seems to be, and I just want some help verifying what you guys think is the line that should go IN to the heater, and which one goes back in to the system.
    heres a picture of the line with the hose valve:
    Here's a picture of the other exposed line, isn't this typically used for draining?
    Here's both:
    Here's the overview without the text:
    And the gas line:
    So to sum everything up. I just want to know which goes in the heater, and which is used as the outtake back into the system. Thanks in advance for your help!
    Default Re: Pool/Spa Combo - Heater Installation - HELP PLEASE!
    I deleted your duplicate post.
    Hopefully, one of our members will be able to help.
  1. Fafco Solar Pool Heater Installation
    By hbv2020 in forum Pool Equipment & Operations
    Last Post: 03-31-2014, 08:59 AM
  2. Need advice re: heater/pump/filter combo
    By ukdavo in forum Pool Equipment & Operations
    Last Post: 05-28-2013, 07:41 PM
  3. Best pump/filter combo for 21' above-ground pool
    By andiques in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2012, 08:22 AM
  4. Pump and filter combo.
    By JohnH in forum Pool Equipment & Operations
    Last Post: 07-09-2007, 03:43 PM
  5. Pool/Spa Combo, Salt and Solar --- Yikes!
    By CalMan in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2006, 11:15 AM
