Re: Green pool with clogged sand filter after 2 weeks out of town
You need an accurate CYA measurement in order to know where you are at so you can target your FC properly. Please do a dilution test - mix 1 part pool water with 1 part bottled or distilled water and then redo your CYA test as normal. Take the results of that test and multiply by 2 to get a correct CYA value.
