Thread: Backwash Valve Leaking
    Sep 2014
    TX
    Default Backwash Valve Leaking
    I've found the forum very informative and decided I would go ahead and register.
    I hadn't really planned on posting, I just wanted to search for info on backwash valves. Guess I'll log back out. :-)
    16,000 gal
    pebbletech
    salt system
    Pentair FNSP60F
    My system appears to be leaking thru the center of the backwash valve. The backwash valve has been difficult to open and close for quite some time. My valve doesn't look like the ones I find online when I search for Pentair FNSP60F backwash valve. Mine doesn't have a threaded top...
    Default Re: Backwash Valve Leaking
    Is that a DE filter?
    Have you contacted Pentair's technical support line?
  1. Need drawing of two position slide valve handle for nautilus backwash valve
    By Rgschell in forum Pool Equipment & Operations
    Last Post: 05-26-2014, 05:51 PM
  2. Pentair Backwash Valve
    By RStalls in forum In-Ground Pool Construction and Repair
    Last Post: 01-11-2012, 08:35 PM
  3. purex triton sm 20-2 leaking out backwash
    By frenchlake in forum Pool Equipment & Operations
    Last Post: 06-09-2011, 08:34 PM
  4. Pentair FNS filter - Hi-flow valve leaking out to backwash
    By naztuk in forum Pool Equipment & Operations
    Last Post: 11-03-2010, 06:46 PM
  5. Backwash Valve help
    By p.p.h. in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 09:14 PM
