Results 1 to 10 of 13
Thread: High FC vs Phosphate testing
    Jul 2014
    Southwest Michigan
    Default High FC vs Phosphate testing
    Hello:
    I was hoping to close the pool this weekend. I super-chlorinated over a week ago (I usually do before closing), but now that I have my Taylor K2006... I'm testing more accurately, and wondering what the pro's might advise me to do.
    FC = 15
    CC = 0
    pH = 7.5
    CYA = 40 < 50
    This week, I purchased a Taylor K1106 Phosphate test kit. My phosphate level is approx. 375ppb. I have some PhosFree and intend to add the recommended dose before shutting down for the winter.
    2 questions:
    1) The K1106 instructions didn't say anything about chlorine levels prior to testing. After I tested, I was reading the dosage amounts on the PhosFree bottle and noticed it recommends testing when chlorine levels are below 5ppm. Is my Phosphate result skewed due to my FC being so high?
    2) Do I need to worry about closing my in-ground, gunite pool with this high FC result? Pool is 35,000 gallons. I use a mesh winter cover.
    I'm able to put winter cover on and delay lowering pool level for the time being if needed.
    Thanks for sharing any concerns.
    Default Re: High FC vs Phosphate testing
    If your pool is clear, no sign of algae, with YOUR numbers you can and should stop wasting your money on phosphate removal. Phosphates are food for algae, no more. Many of us have fairly high phosphate levels (if we bother to test for it at all--I never have) and STILL have perfectly clean and sanitary pools. Phosphate removal DOES have a legitimate place in pool care, but not for 99.99% of us. It's just another revenue-generating scheme.
    Furthermore, we've found that in the rare case where it's appropriate (persistent, tough mustard algae) the EFFECTIVE level of phosphates is far, far lower than the levels the pool stores tell you.
    Jul 2014
    Southwest Michigan
    Hey Carl... thanks for the advice.
    After the kids started school (3 wks ago), I did had some algae start growing in spots on the walls and corner walls, and the water clouded up a little... but not terrible. My FC was never below 7ppm since superchlorinating back in July, and aside from the trichlor in my floater, I was told to hold off adding more sanitizer (I use dichlor) until the FC was down to at least 5ppm. My CC was 0, CYA has been steady at 40, pH 7.2 to 7.4, and I typically toss in 4 oz of algaecide weekly for ****s and giggles. With my levels all seemingly good; I started thinking about what else could be feeding this problem? I had read about the phosphate test/levels in my Taylor manual, so nobody sold me on it aside from Taylor. We got some regular rain here in MI a few weeks ago, and I read that'll boost phosphate levels. I thought the mods here recommended Taylor, but I see you're calling BS on the Phosphate test. I should say, worrying about phosphate levels that is.
    I'm all for that... I just don't get what started tripping me up?
    Thanks again, Carl. If you have more to add... please do. If not, I appreciate the advice and I'm all for not spending on anything unnecessary! Have a great weekend-
    Maybe it's just the inaction of the pool then? My pump runs 24/7, too. I give up.
    For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm.
    For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
    So I very much doubt that your "CYA has been steady at 40". Are you sure you are measuring the CYA correctly? Pool store tests for it can be inaccurate.
    Either your CYA level is higher than you think or you've got poor circulation in the areas of algae or you've got yellow/mustard algae instead of ordinary green algae. Even with yellow/mustard algae, an FC that was 15% of the CYA level should prevent it from growing so again your numbers don't make sense, especially the CYA number given your use of (only?) Trichlor and Dichlor.
    Richard, (Chem_geek) knows the chemistry of pools about as well as anyone here, if not better.
    Basically, he's saying your pool store sold you a bill of goods. IOW, their advice stinks. We can probably help you more effectively.
    Jul 2014
    Southwest Michigan
    Carl & Richard:
    Why do you guys think I go to a pool store? I don't have a pool store in my town, and nobody has sold me on anything. Not sure what I said to get that type of response (?) but it's just me, myself and I here in SW Michigan. As my original post states, I use the Taylor K2006 for my testing. I also posted my CYA was between 40 and 50, but it's not above 50. Seeing the "black dot" disappear is certainly subjective, but my eyes aren't THAT bad. Not sure what any of that has to do with my original post, but wanted to respond. Thanks for the help.
    BigDave's Avatar
    My guess is that pool store was assumed because of the mention of Phos-Free. This is a product that is widely pushed by pool stores - as far as phosphate removers go it's quite expensive and removes relatively little phosphate. Please don't be upset, we see Phos-Free pushed by pool stores all the time.
    Post #3 is puzzling, If you used only dichlor and trichlor I'd expect CYA to be much higher. Did you change water this summer? Is it possible the pool went for some time with little or no FC?
    What kind of algaecide have you used?
    Mustard algae usually appears as yellow patches on the bottom or sides of the pool (in shady areas) that disperse readily with a brush. As it grows the yellow will become greenish. It usually doesn't cloud the pool. Phosphate level 125ppb or lower helps suppress mustard algae effectively.
    Quote Originally Posted by TCP007 View Post
    Carl & Richard:
    As BigDave said, when someone starts talking phosphate levels, we assume they were talked into it by a pool store. Why? Because other than discussions amongst the support team, you are, I believe, the FIRST person to mention them WITHOUT being pushed into it by a pool store! Leslie's has a whole phosphate reduction package plan, selling regular doses of reducer--and it is (or was) a big money maker for them.
    We are just trying to help and when we see apparent anomalies, we question the test results that lead to them. That's all.
    Jul 2014
    Southwest Michigan
    BigDave: No water change, but yes... I stopped adding granular dichlor since I super-chlorinated with liquid chlorine in late July. A mod here recommended I stop adding sanitizer until my FC was at or below 5ppm. I actually added my floater back to the pool in mid August because I was worried about not having any sanitizer whatsoever. The floater holds about 1-lb of 1" trichlor tabs that typically dissolve in about 1 week. But that's the only sanitizer I have added since late July until about 2 weeks ago. I test my water every Saturday, and my FC was still at 7ppm the week prior to this last, minor outbreak.
    I buy online from InTheSwim. I've never spoken to anyone there. The information about phosphate testing is right in the Taylor booklet. I can't be the first person to ever decide that testing for phosphate might be a good idea (?)
    Anyway, the pool is ready to be closed. I didn't realize phosphate testing was the Loch Ness Monster of pool maintenance. Nothing ventured, nothing gained.
    Usually, nobody says let your FC drop below 5ppm unless you're dealing with a metals issue.
    Are you aware that Dichlor adds lots of stabilizer/CYA, and so does Trichlor, and that Trichlor is also very acidic? Liquid chlorine/bleach adds nothing but chlorine so it's always safe to use.
    We generally do NOT recommend phosphate testing because, except in peculiar cases, it's USELESS.
    However, it is your pool and the ultimate responsibility for it is yours. We can only make suggestions.
  1. Phosphate testing
    By Big Splash in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-15-2014, 05:05 PM
  2. high phosphate levels
    By NeedSOS in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2012, 10:08 PM
  3. Extremely High Phosphate count
    By JHarrin458 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2011, 01:57 PM
  4. high CYA and phosphate reading
    By vivian in forum Dealing with Algae & Slime
    Last Post: 08-05-2006, 11:44 PM
  5. High Phosphate 2500 - Options?
    By Slam Pool Guy in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2006, 09:39 AM
