Thread: Pool closing
    Sep 2014
    Ontario
    Default Pool closing
    Hi.
    I need some info on above ground closing process including required chemicals.
    Thanks.
    Default Re: Pool closing
    There is a stickied thread at the top of the Pool Start-up and Closing section that explains closing an AG pool that will probably be helpful for you. But, until your registration is completed, you won't be able to see the rest of the forum while you are logged. So, log out first and go read it. Then, if you still have questions, post them here and someone will try and help.
    Welcome to the Pool Forum!
  1. Closing Pool :(
    By 392papa in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-22-2012, 10:33 PM
  2. Closing a.g. Pool
    By willis1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-15-2012, 11:23 PM
  3. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. Closing pool
    By bryjen in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-19-2006, 10:24 AM
