Thread: Chlorine Tablets Vs Liquid... Worth $700 for CYA?
    Sep 2014
    DE
    Default Chlorine Tablets Vs Liquid... Worth $700 for CYA?
    My pool company said I have a CYA issue due to using Chlorine Tablets for a community pool. I read where the solution is to drain 1/4 of the water for 4 weeks and then you are good.... Anyway they are proposing a switch to liquid chlorine for $700 to fix the issue
    1-Is switching to liquid chlorinator system the solution
    2-Is around $700 the correct price?
    Default Re: Chlorine Tablets Vs Liquid... Worth $700 for CYA?
    Hi!
    While we are not a community pool forum, Ben (PoolDoc) has managed many of them over the years.
    CYA is stabilizer and an "issue" means it's too high. But how high IS too high? Without a measure we cannot tell. The easiest way to lower CYA IS by dilution, but that's a straight-forward relationship. If your CYA is, say, 200ppm (which IS 'way too high!) draining and replacing 1/4 of your water should get you to 150ppm, still 'way too high.
    Liquid Chlorine is....bleach, just a stronger concentration. I buy 12.5% LC for less than $2/gallon. 1 gallon will raise the chlorine level in a 10,000 gallon pool 12.5ppm, or 1/10th of that in a 100,000 gallon community pool.
    So how big IS your pool?
  1. How/When to use chlorine tablets?
    By Spookypaws in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-30-2013, 01:05 PM
  2. Does anyone use these? chlorine tablets
    By kimkats000 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2012, 07:13 AM
  3. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  4. HTH Non-stabilized chlorine tablets
    By vanhout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2006, 10:42 AM
  5. Chlorine Tablets
    By larubia in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-23-2006, 01:14 PM
