Results 1 to 10 of 15
Thread: Cover Options and Cover Types
    Virginia
    Default Re: Cover Options and Cover Types
    I'm not covering mine this year!
    Yeah, Carl has solved the water drainage issue by removing the pool walls...lol.
    Quote Originally Posted by swimdaddy View Post
    Thanks Watermom, makes sense and seems practical with less hassle. So my question is why would anyone cover there pool? It seems like some do and some don't, so what are some reasons someone would want to cover their pool.
    I think a lot has to do with the environment around the pool. It seems like around here there's always something in the pool year round.
    When I was using a mesh cover, a lot of fine dirt would accumulate in the pool which was a big PITA to manually vacuum in the spring (I hate manually vacuuming). Also, it meant closing much later and opening much earlier, so there were several months of pool maintenance when it was too cold to enjoy. Switching to a solid cover made spring cleanup much easier and faster, and I can close/open when I want (usually Oct/May).
    That said, the cover can also be a pain. If our pool didn't get so dirty with the mesh cover, I'd be inclined to try Watermom's coverless method.
    Quote Originally Posted by JimK View Post
    Yeah, but I wouldn't recommend it on a seasonal basis!
    Oct 2011
    Southern New Jersey
    Great discussion about to cover or not to cover. But, if I DO cover, I'd still like some feedback on my proposed methods of covering. Has anyone else used (or heard about) the PVC frame method? If so, what are you thoughts?
    Steve Romo (6700g AG, Cartridge Filter)
    Not heard of the PVC frame method, but if snow builds up on it and turns to ice it could collapse, I'd think. Remember: 1 cubic <foot--sorry> YARD of water weighs about 1750 lbs--7/8 of a ton!
    Virginia
    Not heard of the PVC frame method, but if snow builds up on it and turns to ice it could collapse, I'd think. Remember: 1 cubic foot of water weighs about 1750 lbs--7/8 of a ton!
    Actually, 1 cubic foot weighs 62.3 pounds.
    http://www.ask.com/science/much-cubi...1656c2efc1f7c8
    Sorry. I typed "foot", meant "yard" and there are 27 cubic feet in a cubic yard.
    (BTW, the 62.3lbs is for distilled water, not water loaded with chlorine, calcium, salt, etc, which is closer to 65lbs)
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    I am not sure you could safely build a "tent" to avoid puddling without endangering your liner. I suppose you could go nuts and buy enough pillows to fill the entire surface of your pool, and as long as they were taller than the pool side you would get some drainage. However, once again snow would not drain off, and any dips or valleys in your cover between pillows would suffer a lot of pressure and potential damage. The point of the "pillow in the middle" with slack in the cover is so that the cover is always supported from underneath by the water/ice or the pillow, and its not pulling too much on the pool sides. Puddling may just be an unavoidable consequence.
    Jun 2011
    We cover our pool every year with the loop loc cover..It keeps the neighbors leaves out of it and we tend to get a lot of wind. It stays reasonably clean, we add our chemicals if needed through the skimmer usually just the chlorine tabs. We do chemical it before covering for the season. We run the pool 5-6 hours every day/night we switch to night time for the cold, we have an intelliflo variable speed pump.. The only problem we have is trying to set the pump from summer to winter time, we find that very confusing we got this pump last year.... We remove the cover in the spring before we turn on our solar heater for the season, usually in April sometime and we change the water every three to fours years ..We really like our cover it does save a lot when getting ready to open for the season..We live in Las Vegas
  1. Intex debris cover or solar cover
    By Larryh86GT in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 06:06 PM
  2. What are options for pool cover to use daily?
    By DistantHorizon in forum In-Ground Pool Construction and Repair
    Last Post: 09-03-2011, 09:56 AM
  3. Solar Cover as Winter Cover?
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2007, 11:46 AM
  4. Solar cover under winter cover?
    By margekendall in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-18-2006, 10:49 AM
  5. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
