Thread: pump questions
    mas985's Avatar
    Pleasanton, CA
    Default Re: pump questions
    Neither. With a single speed, 4 hours is probably all you need and with a two that might be all you need too. I get away with 4 hours per day and 3 three of those hours is on low speed.
    Mark
    But what's the volume of the pool?
    Aug 2014
    Ohio
    I have no water features. pool is approx. 20k gallons.
    mas985's Avatar
    Pleasanton, CA
    Mine is 20k too so a reduced run time is certain possible. Most people find they can get away with very little run time if they just try. So to I would go with both a two speed and a timer.
    Mark
  1. New Pump Questions before I Buy
    By sosspenc in forum Pool Equipment & Operations
    Last Post: 07-27-2012, 09:35 PM
  2. Questions about pump and filter
    By tim665214 in forum Pool Equipment & Operations
    Last Post: 07-26-2012, 04:46 PM
  3. Pump questions
    By nikki527 in forum Pool Equipment & Operations
    Last Post: 10-12-2011, 03:16 PM
  4. Pump runtime questions
    By iBrew in forum Pool Equipment & Operations
    Last Post: 08-10-2011, 11:07 PM
  5. I have a few questions before I buy a new pump..
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-21-2006, 05:02 PM
