Thread: How raise ALK and keep pH in range
Threaded View
    Downingtown, PA
    Question How raise ALK and keep pH in range
    Having trouble raising TA and still keeping pH in range. I have a 29000 gal concrete pool, DE filter, and 2 months old in the Phildelphia region. I last shocked 4 days ago with Ca Hypo (trying to get Ca in range). Water is crystal clear. Results:
    pH=7.8
    TA=110
    Ca=220
    Cl free=1.0/1.1 total
    CYA=28
    I added 10 lbs of baking soda 4 days ago to correct a low TA (it was 70ppm with a pH of 7.5). Every day since I have had to add 22floz of muratic acid to keep pH less than 7.8. Today pH shot up to 7.8, so I added 30floz of acid. I have been diluting the acid in a 5 gal bucket and spreading the contents evenly around the pool sides in the deep end. I use TRI pills for maintaining Cl at low ppm level since I have a Nature 2 system
    Am I doing something wrong? or should I just let things settle? I do not understand why pH keeps rising everyday. Aprreciate the help as I am a new pool owner. Pool was first filled in late April.
    Don
  1. Replies: 6
    Last Post: 04-25-2012, 05:12 PM
  2. Cannot seem to raise Ph
    By D_Case in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-19-2012, 01:45 PM
  3. No CYA - How to raise it?
    By mortimay in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2011, 06:33 PM
  4. Cant seem to raise TA or PH
    By drbob101 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-11-2010, 11:41 PM
  5. Extending the Range of Test Kits
    By expose in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 03:30 AM
