Thread: Getting cold need to close the pool
    May 2014
    Colorado
    Default Getting cold need to close the pool
    It's getting really cold here in CO and it's time to close the pool down. We had a dusting of snow already. I tested the water and was wondering how it looks.
    above ground, about 10,000 gallons, swg, 1600 gph sand filter
    alk = 80
    fc = 9
    cc= 0
    ph = 7.5
    cal = 60
    cya = 40
    This is our first year and I'm not sure that process and could use some help. I read to use some 60% polyquat algaecide, can I get that at walmart? Does anything need adjusted? Thanks much
    Default Re: Getting cold need to close the pool
    There is a stickied thread at the top of this section of the forum with some information about closing an AG pool that should answer most of your questions. If it doesn't after reading it, post further questions here and someone will try and help.
  1. Filling a new pool in the cold?
    By Pibster in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2012, 05:56 PM
  2. AG pool has a leak - close or fix now?
    By powiebaby in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-08-2008, 01:21 PM
  3. when can i close my pool
    By kickurasin in forum Above-Ground Pool Construction & Repair
    Last Post: 09-11-2007, 12:55 AM
  4. Does anyone NOT close pool?
    By maureenc26 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-19-2006, 10:39 PM
  5. Can I close a dirty pool?
    By housemom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-01-2006, 01:14 AM
