Results 1 to 10 of 17
Thread: First time pool owner with lots of questions
    Default Re: First time pool owner with lots of questions
    Welcome! First, I think your estimate is 'way too high. a rectangle 18x36x 4' deep is 2592 cubic feet. At 7.48 gallons per CF, you'd have 19388 gallons. Obviously, curves and angles make calculation more complicated, but if you know the cubic feet, multiply by 7.48.
    Do you have a reason to think your sand filter is either defective or too small? It may be, and going to a bigger sand filter will generally give you better performance.
    We call them "Guess Strips" because they are almost impossible to read accurately. We recommend the Taylor K-2006 instead.
    http://www.poolforum.com/pf2/showthread.php/14994
    What are you shocking with? If you use Dichlor or Trichlor and your stabilizer level is high you'll just make the problem worse.
    Sep 2014
    Memphis,TN
    Thanks Watermom!
    do you have any recommendations for a great sand filter. I've been told that it will run me about $1K. I've also been told to wait til the fall or winter so they will have better deals since it's their slow time.
    Though I still stand by the advice that you can't go too big with a sand filter ------ I was just talking with Poconos, a former forum moderator who is more of a pool equipment guru than I am, and mentioned this thread. He agreed that you could use the bigger filter but also thought that the 24 inch one (300 lbs of sand) would actually do just fine on your size pool and would save you money. I have a Hayward filter but can't tell you specifics about their various models.
    Sep 2014
    Memphis,TN
    any recommendation on chemical brands? or just chemicals in general... so far i've only been using the chemicals that homedepot sells since... I know i'll probably get yelled at for doing that but it is just so convenient, that is until i buy the chemicals off of amazon.
    For chemicals, go to our sister site, Poolsolutions.com and see the following!
    http://www.poolsolutions.com/tips/po...ery-store.html
    Yes, it's really, really true. Ordinary chemicals you can get at your supermarket are packaged and marketed as super-de-duper magic (and expensive) miracle fixes!
    So...for Chlorine: Bleach or Liquid chlorine.
    For raising pH: Borax or Washing Soda.
    For increasing Alkalinity: Baking Soda.
    For decreasing pH: Muriatic Acid or generic Dry Acid
    For stabilizer: CYA powder.
    And that's really ALL you need to maintain a sweet, sanitary, safe pool!
    Sep 2014
    Memphis,TN
    OK... I had a friend of mine take my water in to get tested while I wait for my testing kit.. here are the results.
    Free available chlorine = 4ppm
    total available chlorine = 4 ppm
    calcium hardness = 100 ppm (low)
    CYA = 55ppm
    total Alkalinity = 160ppm (high)
    ph 7.8
    copper 0
    iron 0
    phosphates 0
    my water is still cloudy it's much less green today...
    1) i was told to pu in 4lbs of green to clean, wait 5 min and shock it with 5lbs of shock wait 12 hrs and shock it with 5 lbs of shock and the if it is still cloudy use clarifier. should i do this? I'm thinking maybe...
    I back washed my sand filter yesterday and it was pretty dirty so i'm hoping the water will clear up...
    2) They also recommended me to put in Muratic Acid or Dry acid to lower alkalinity .. should i do this? I'm thinking yes...
    3) They also said to add 48lbs of hardness plus to raise calcium hardness... should i do this? I'm thinking no way... What good is calcium hardness for in a vinyl pool?
    Last edited by Watermom; 09-11-2014 at 12:12 PM. Reason: To add numbers to make it easier to respond
    Sep 2014
    Memphis,TN
    Thanks Carl!
    I'll buy that test kit as soon as possible. I'm pretty sure I'm using the Trichlor. according to the test strips the stabilizer and alkalinity are the only things low.
    the pool is 18x36 but it has an 8 foot deep end and a 4 foot shallow end. Not exactly sure how quickly it slopes since I've never been in there.
    As far as the sand filter goes, the filter seems to be leaking slightly from the top, the pressure gauge when we bought the house was completely missing and when we closed on it there was a new one that was fixed to the top of the filter with some kind of apoxy putty. we've had literally 3 or 4 pool companies inspect the pool and tell us what we should do/need to do, only one said that we should probably get a new sand filter. However, all of them said that the pool is old and at the "end of it's life" not sure what that exactly means.
    my water is as of today a light aqua color and slightly cloudy. I've been running the pool cleaner 5 or 6 times in the last 3 days .. I've started with a bag insert to capture the big debris and am now using the 2 micron filters. hopefully the cloudiness will go away soon. it does look noticeably better.
  1. New Member, New Pool, Lots of questions
    By riverwhiskey in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-22-2012, 07:56 AM
  2. New Member/New Pool/Lots of "old questions
    By box0785 in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-29-2012, 08:32 PM
  3. first time pool owner and first closing (still with questions)
    By rannrich in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-14-2011, 05:30 PM
  4. First time pool owner questions on filter and pop-up floor cleaners
    By bpuck in forum Pool Equipment & Operations
    Last Post: 10-12-2011, 06:41 AM
  5. New homeowner, pool owner lots of q's!
    By booztedgt in forum Dealing with Algae & Slime
    Last Post: 07-09-2010, 03:34 PM
