Page 11 of 16 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 101 to 110 of 155
Thread: Test results on new pool in Tucson
  1. #101
    Jul 2013
    Northern Illinois
    Default Re: Test results on new pool in Tucson
    Remember to go through PoolDoc or WaterMom's links whenever buying on Amazon! And remember also, that Amato Industries discounts shipping for multiple items upon check-out (not before). Check especially your supplies of : 0871. 0870, 0004, and 0013. Most keep well over time and stored out of sun and cool-ish.
    Last edited by FormerBromineUser; 09-16-2014 at 09:27 PM. Reason: Remove that dang signature!
  2. #102
    Jul 2013
    Northern Illinois
    Uh, sorry. Another thought. At 500G, can you just drain and refill that spa? AND please make a signature so we won't forget your spa in the future!
  3. #103
    Wilco's Avatar
    Wilco is offline Registered+ Thread Analyst Wilco 0
    Aug 2014
    Tucson
    Cool Re: Test results on new pool in Tucson
    I did accidentally drain it about 3 weeks ago, not sure how I did it or how it refilled. How's that for competence?
  4. #104
    Wilco's Avatar
    Aug 2014
    Tucson
    I'll see where things are in am, again with monsoon rains, it may work for me a little
  5. #105
    Jul 2013
    Northern Illinois
    Okay. Will wait to hear. Maybe monsoon rains could refill that spa! But really? Not sure how you drained and refilled? That sounds like the systems are connected somehow. I know nothing about hydraulics but that doesn't make sense to me.
  6. #106
    Quote Originally Posted by FormerBromineUser View Post
    Regardless, it's not the pollen that is causing your chlorine demand.
    Actually, pollen in the water will increase chlorine consumption. Anything organic in the water will. It is not the entire cause of his issue but just wanted to clarify that anything organic in the water (pollen, leaves, etc.) will use more chlorine.
  7. #107
    Wilco's Avatar
    Aug 2014
    Tucson
    Retested this am, spa ph at 7.2, chlorine levels held at 17 at both pool and spa. I think I'm making progress ( but won't let foot off gas yet)
  8. #108
    Jul 2013
    Northern Illinois
    ...just wanted to clarify that anything organic in the water (pollen, leaves, etc.) will use more chlorine.
    Important clarification, thanks!
  9. #109
    BigDave's Avatar
    I'm not sure if this helps or not, but, mary jo had a very similar situation in this thread: http://www.poolforum.com/pf2/showthread.php/25802-Clear-but-no-chlorine. The pool had high CYA and chlorine demand after an extended period of insufficient chlorination. The good news is that it was eventually resolved by maintaining shock level FC for a very long time.
  10. #110
    Jul 2013
    Northern Illinois
    Mary Jo (see above link) read your thread and wondered about your CC. Last reading I saw was on the 14th or so. Spa? Pool? Either greater than 0.5?
  1. Need help w/test results
    By The Mermaid in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 05:26 PM
  2. More Test Results!
    By mkfmedic in forum DPD-FAS based testing
    Last Post: 09-12-2006, 01:15 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 03:27 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 01:48 PM
  5. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 07:30 PM
