With a CYA of 50, you want to try and keep your chlorine between 3-6 all the time. Here is what to do. Each evening, test the chlorine. Add enough bleach to take your chlorine back up to 6ppm. The next evening, if you find that your chlorine has dipped below 3ppm, take it up to 7ppm when you dose with bleach. The goal is to find out how high you need to take it so that it never drops below the minimum by the next evening. You will soon learn your pool's pattern.
In case you need the Best Guess Chart again, it is here: http://pool9.net/cl-cya/
I think this is the post to which you were referring. Your CYA is now 60 so you need to bump up WaterMom's original minimum recommendation for maintenance.
HOWEVER, you now have algae. CarlD will advise you what to do but in the meantime, reread the Best Guess chart linked above.
Sorry, Carl. We posted at the same time....
