Results 1 to 10 of 17
Thread: Need help with identification.
    BigDave's Avatar
    Default Re: Need help with identification.
    Why are you trying to figure out the manufacturer? Are there broken / missing parts?
    Jun 2014
    A northeast state
    It has a leak somewhere. Was quoted $400 to find it. Then there is the cost to fix. Trying to determine if it's worth it.
    Kevin
    15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
    Wow! If the leak is from the liner, the hardest part is finding it, but you can make repairs yourself even under water.
    If the leak if from the plumbing, there's NO reason on an AG pool to not locate it and fix it. Above Ground Pool plumbing is rarely complicated.
    Finding a leak requires a dye, like "Find A Leak" (one brand). Some are even fluorescent but I've not used them. You find the likeliest area by searching for where it's wet outside the pool. Turn off the pump and let the water get very still. Add the dye and wait. If it's near the leak in 10-30 minutes it should collect at the leak point.
    Then you patch it.
    Plumbing leaks should be easier to find unless you have buried pipes. Look for drips.
    Jun 2014
    A northeast state
    The leak is not from the plumbing, I've already checked. It just seems like I'm losing too much to evap. Like 1/2 to 3/4 inch per day. Can the bucket test be done if the bucket isn't in the water? My ladder won't accommodate a bucket. We've also had very little rain this summer, which I'm is a contributor to all of the water I've had to add.
    Kevin
    The bucket test shows vividly whether the pool level is going down faster than the bucket level. If the water level's going down but the bucket's water level isn't, you have a leak. If they go down the same, it's evaporation.
    1/2 to 3/4 is a lot for the NE. Can you see any wetter spots around the pool?
    The bucket doesn't have to be in the pool. Just set it beside the pool on the deck. Use something to mark the level on the pool and on the bucket so you'll have a reference mark on each to measure the level of change.
    Jun 2014
    A northeast state
    Did the bucket test. According to my wife (she checked, I'm at work), we lost an inch from pool and two inches from the bucket. I'm more confused.
    Kevin
    Leaky bucket? Dog or deer drinking from the bucket? If it's where animals can get to it...they will.
    Jun 2014
    A northeast state
    The price I pay for marrying a blonde: I measured when I got home. I lost 1/4 inch from the bucket and 3/4 from the pool. I'd say that I have a leak.
    Kevin
    Jun 2014
    A northeast state
    That is what I did. Put it on the deck next to the pool. They are calling for showers later today and tomorrow. We will see. Every time they have called for rain we've gotten very little.
    Kevin
  1. Coping Identification for Inground Vinyl Liner
    By 66Corvette in forum --cleanup--
    Last Post: 06-06-2013, 11:49 PM
