Thread: Can rain make pH rise?
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default Can rain make pH rise?
    Luckily we don't get a lot of Rain in Las Vegas, however it does seem that after each rain my pH rises, any connection?
    Intex Ultra 16' x 48 5,061 gallons, Intex SWG, Intex 1,500 gph pump K2006, Unicel, city water
    Default Re: Can rain make pH rise?
    Generally, rain may make your pH go down--acid rain. If it's going up it may be either coincidence or somehow, the rain is causing the pool to aerate--and that pushes up pH.
    Other possibilities: If you are chlorinating with cal-hypo and covering the pool when it's raining, the cal-hypo could be pushing pH up.
    I'm just guessing here......................
  1. Does Ph naturally rise in the pool?
    By Bosch232 in forum Pool Chemistry for Intex-type Pools
    Last Post: 03-30-2013, 06:41 PM
  2. Minimizing pH rise in SWCG pools
    By Watermom in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-13-2012, 11:55 PM
  3. Make sure I have this right - TA and CH
    By Trimom in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2007, 04:37 PM
  4. pressure rise with new sand filter
    By induce in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 06:38 PM
  5. What causes Calcium to rise?
    By SoCalBoo in forum Dealing with Alkalinity and Calcium
    Last Post: 06-20-2006, 01:51 PM
