Results 1 to 10 of 17
Thread: BioGuard balance pak 100
    May 2014
    Abilene, Texas
    Default Re: BioGuard balance pak 100
    I used the BioGuard the PB gave me. From the research I've done on this sight and my SWCG manual my goal should be 80 but since I won't be turning it on for at least 3 more weeks I was shooting for 40 for now.
    Marty
    33 x 23 modified kidney IG Diamond Brite 18K gal
    Pentair CCP420 filter; Jandy Stealth 1.5HP 2 spd pump
    Taylor K2006 test kit; Hayward SwimPure Plus T-Cell 15
    OK. Do not add anymore CYA for a while--wait about 4-7 days, then test it again. CYA takes an ANNOYINGLY long time to dissolve, from 2 up to 7 days. Otherwise you risk overshooting your target.
    Otherwise your numbers look pretty darn good. (don't know how you got "34" for CYA though--anything between 30 and 40 is a total guess--halfway is NOT 35!) Be sure to check the Best Guess Table at
    http://poolsolutions.com/gd/best-gue...ine-chart.html
    for the best FC levels for your CYA level.
    May 2014
    Abilene, Texas
    Ya I guessed at 34, it was closer to 30 than 40. Anyway figured it was close enough for a week to let it all dissolve. I'm shooting for 4-5 for chlorine.
    Numbers look good because of this sight. I've done lots of reading the past few months, so thanks to everyone that contributes to the knowledge pool.
    Marty
    Jul 2013
    Northern Illinois
    You are welcome! I just reread the thread and noticed that you said you added 55oz Hasa acid (31.45%). Please tell me you didn't measure it. If so, please read info on MA safety: http://www.poolforum.com/pf2/showthread.php/13111
    May 2014
    Abilene, Texas
    I didn't measure the acid, just an estimate. I marked the side of the jug with a sharpie and sticky thread on this site, same one you linked.
    Marty
    Jul 2013
    Northern Illinois
    Oh, phew! 55oz just seemed like a measurement. Keep us informed of your progress!
    Best,
    Randy
    Jul 2013
    Northern Illinois
    How are things going? Have you tested your CYA yet?
  1. Sandman15 first Post-Problems with Bioguard SWG
    By Sandman15 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2011, 12:03 PM
  2. Bioguard Softswim??
    By yjjeeper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2007, 09:25 PM
  3. CYA and Bioguard sticks
    By BigStein in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-18-2006, 06:08 PM
  4. Help new BioGuard Mineral Springs
    By wsmith002 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-19-2006, 05:01 PM
  5. Help - problems with Bioguard MS11
    By kevinm in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-19-2006, 06:53 PM
