sounds great bigdave. i have only added a 1 gallon jug of liquid choriline so far from doing the test. Leslies told me my stablizer was low so I added that at the beginning of the week. I am trying to add stuff slowly to learn how everything is effected.
Is borax better to use than the muratic acid? I have both but have only used the borax to dry out deer skin and clean laundry with.
I question why the kit came with only double of a couple items and after doing my first test at 25ml, I can see how you can go through some taylor products.
I will start with the two suggestions and repost my numbers later.
Thanks for all the help.
