Results 11 to 16 of 16
Thread: Found this forum too late -- need some guidance on a conversion already begun
    Default Re: bright Gatorade green -- am I really close?
    Quote Originally Posted by eyesfinallyopened
    Okay, I've kept the FC level at 10-20 ppm all day, despite the sizzling AZ sun. It's been a roller-coaster of emotions because it's looked horrible most of the day but actually started looking clearer around 6:30 p.m. and I can now see the bottom drain and the ladder. No more floating junk, either.
    Anyone want to venture to guess when I might get the amazing transformation?
    Thanks,
    Deborah
    I would have to say that you are well on the way....just keep up the chlorine and keep backwashing the filter!
    Default sigh. still Gatorade-y but much clearer
    This morning I could clearly see the precipitate that I'd missed yesterday on the bottom of the pool when I vacuumed. So, I got that all up and topped up the FC level which had dropped to around 10 between 2:00 a.m. and 5:30 a.m.
    Hoping to see some blue later today or tomorrow.
    --Deborah
    Default very pale green & crystal clear!
    This is much better but I need just a little more hand-holding before all is said and done.
    I'm keeping the FC at 15ppm, brushing sides and bottom, vacuuming, cleaning the sock liner and backwashing frequently. My understanding is that the pool will miraculously change to a beautiful blue color at which time I should change out the sand in my filter and use borax, baking soda and CYA to maintain the correct water readings.
    Is there anything else I should be doing right now? I'm starting to wonder if I should go ahead and put fresh sand in the filter. Could the stuff trapped in the sand be hampering the water's ability to get to that pretty blue stage?
    Thanks, everyone!
    Deborah
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Default Re: Found this forum too late -- need some guidance on a conversion already begun
    You don't want to change the sand until all of the Baquacil is destroyed, or you will have to change it again. Hang in there, it took me about 5 days to go from pea green soup to pristine clear water.
    Default my pool has never looked better!
    Wow! I'm so happy with my pool and I just want to thank all of you that took the time to help with this process. I'll post some pictures soon in hopes of helping the next poor soul that needs to get rid of the Baquacr$p.
    --Deborah
  6. #16
    Hi Deb...congrats on completing the process!!! I was happy to read your update. How long did the whole process take and how did the showing go????
    -REV
  1. new pool glad i found this forum
    By udg21 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2012, 09:28 PM
  2. new to the pool forum wish I had found you sooner, wall foam ?
    By blackthumb in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2011, 04:07 PM
  3. New to forum and BBB..Needing guidance.
    By 4toads in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-05-2011, 04:36 PM
  4. Installation Has Begun!
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 09-02-2006, 02:51 PM
