Thread: sticky brown residue on top of intex easy set pool ring
    Aug 2014
    Iowa
    Default sticky brown residue on top of intex easy set pool ring
    This year for the first time after removing my pool cover after vacation there was a strange brown sticky residue
    on the of the pool ring all the way around the pool. I have an Intex easy set 18 X 48 pool. This has never happened before. This residue is not mold and can not be scraped off. We had to go on vacation again about a month later
    and put the cover back on .. Now the residue is even worse. Has anyone ever experienced this and can it be cleaned?
    Seems like the liner is ruined for good.
    Default Re: sticky brown residue on top of intex easy set pool ring
    I'm trying to think of what it could be. Is it from where the cover contacted the inflatable ring? Or at the waterline? If it's from where the cover contacted the ring, then there's probably something eating your cover and it should be discarded. Not sure what you can clean the residue off with that won't damage the ring, though is sounds like tree sap.
  1. How to Find Leaks in Easy Set Inflatable Ring
    By hollyp53 in forum Intex-type Pool Setup & Operations
    Last Post: 07-28-2014, 08:53 PM
  2. Slightly cloudy with brown residue at the bottom
    By proximo in forum Dealing with Algae & Slime
    Last Post: 07-12-2013, 11:22 AM
  3. Problem with cloudy in-ground pool. Brown residue on liner.
    By crosspoint in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-28-2012, 11:51 PM
  4. Blackish/Brown Sludge on Ring - Intex Easy Set
    By mstreeter78 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-13-2012, 02:14 PM
  5. Brown oily ring around pool
    By Pamela P. in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2012, 01:22 PM
