Results 1 to 8 of 8
Thread: Single mom 18000 gallon, de filter chlorine pool w hot tub- old school plaster
    Aug 2014
    Houston,Tx
    Default Re: Single mom 18000 gallon, de filter chlorine pool w hot tub- old school plaster
    Thank you Watermom!! I've been using granulated Calcium Hypochlorite hydrated oxidizer to shock. It says it's 73% calc hypo and 27% Other. The chlorine tabs are 99% Trichloroethane-s-triazinetrione and 1% Other. Available chlorine is 90% in the 3" tabs.
    Currently the chlorine is at a 2 and ph 7.5. I added about 50 oz of the 8.25% bleach last night and my last three chlorine tabs. I plan to buy the CYA Powder and cal-hypo today and will test again this evening. How should I add the 2lbs of cya? Broadcast it or put it in the skimmer? Also, is there a clever way to hang the sock over the ledge and return jet? Stocking holder maybe?
    My water looks beautiful and clear today. I think it's the bleach I'm adding daily. There's not any visible algea but a slimy feeling in the stair crevices. I think I'll try to shock with the bleach after I add the cya and hypo calc. Will report back after testing tonight
    You guys are Awesome!
    You can just use some string to wrap around the sock and then wrap the string around the top edge of the pool or use some duct tape or something. Or, just pour it slowly into the skimmer while the pump is running and then keep your pump running 24/7 for 4 or 5 days after you add it and don't backwash during this time. About a week after you add it, run the CYA test again and report your number.
    Glad the water looks good. Hopefully, we can help you keep it that way!
    BigDave's Avatar
    @Watermom: OP has a DE filter. Do you recommend adding CYA in skimmer with a DE filter?
    Better to put it in a sock in front of a return.
  1. 10k gallon pool - Re-plaster
    By eruppert in forum In-Ground Pool Construction and Repair
    Last Post: 03-05-2014, 06:27 PM
  2. 10ft x30 intex pool with 530 gallon filter i need help with HTH chemical please
    By suezy in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-22-2013, 09:43 AM
  3. What is best pump/filter for 300 gallon kiddie pool?
    By Beverly in forum Above-Ground Pool Construction & Repair
    Last Post: 07-12-2011, 07:37 PM
  4. Help with filter selection for in-ground 35,000 gallon pool
    By rshady in forum Pool Equipment & Operations
    Last Post: 06-02-2011, 03:50 PM
  5. Help Size Pump and Filter and Calculating Gallon Capacity of Pool??
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2006, 02:45 PM
