Results 1 to 10 of 19
Thread: Inground Pool Cover Recommendations?
    Macedonia, Ohio, USA.
    Default Inground Pool Cover Recommendations?
    I have been using a mesh safety cover for 17 years with my inground pool. I believe the cover is on its last legs (mice even chewed some holes in it), so I am looking for recommendations to replace it.
    The pool is 20x40 IG, 27.5K, and a roman design on the deep end. We live by Cleveland Ohio, so crazy winters.
    I've read some posts where folks are going away from the mesh covers, which then requires pumping water off the solid covers throughout the Winter.
    In talking with Pool Companies, they said that mesh covers are still the ones normally ordered, and that the higher quality covers now have a much tighter weave so no sun, and much less debris get through.
    Would love to hear your thoughts on the best way to go. With the roman end, the cover will most likely be custom for me, which I understand will be move expensive than normal.
    Joe
    Default Re: Inground Pool Cover Recommendations?
    Some of the companies sell patch kits for mesh safety covers so you can get some more years out of it.
    Thanks, I'll check into it. There are about 5 holes though, and unfortunately they are pretty large from the mice.
    Interesting thought Watermom. The only drawback I would see are leaves which hit in the fall - it would be a real mess for us. I may be able to just cover during the leaves, then remove for the winter though.
    No detriments to the liner being exposed to the sun all year versus the normal 7 months with a mesh cover?
    I live in WV where we have lots of trees and I have a really big one right beside my pool. I am just diligent about keeping leaves removed in the fall and then once they have all fallen, we are good to go. I open my pool pretty early each year since we go from winter to summer temps pretty quick most years. I always open to clear water although there will be a little dirt on the bottom. That is no big deal; a quick vacuum easily takes care of it. There have been no issues at all for us without using a pool cover. Haven't used one in years. (Another former moderator who lives in NE Pennsylvania also never covered his pool in the winter without issue.)
    Just something to think about. In my opinion, winter covers are a big PITA!
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    A couple of years ago I purchased a Loop-Loc mesh cover, I previously had a solid winter cover held down with waterbags. I hated pumping the water off of that cover and raking the leaves off of it. I was in heaven that first winter with my new Loop-Loc cover, no pumping, no raking , wow, it was great!
    I was shocked when we opened the pool that first year, it was a swamp. It took me every bit of 7 days to get that water clear. I now hate my cover. There are 2 other Loop-Loc cover types, one is solid and comes with a pump, the other is solid with a few mesh panels to let the water through, but not as much sun. The latter is the type I'll buy when this one needs replacing.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    Virginia
    I started out with a mesh cover when our pool was installed. After several years I started covering the mesh safety cover with a tarp style cover for my own version of a solid safety cover. Either way I have to pump water out of the pool or off the cover. Spring cleaning is MUCH easier with the solid cover; no extra dirt/debris and winter chems aren't diluted over the winter.
    I had considered Watermom's no cover approach, but the thought of maintenance during the winter doesn't appeal to me.
    Quote Originally Posted by JimK View Post
    I'm not sure what you mean. I have no maintenance over the winter. Once we get the leaves out in the fall, we're done til spring.
    Virginia
    Here it seems like there's always something dropping in the pool year round (we're surrounded by a variety of trees). With the mesh cover there was quite a bit of fine dirt that had to be vacuumed up in the spring (took several vacuumings...a real pain IMO). I imagine uncovered there would be quite a bit more dirt.
    Also, I would have to "close" much later in the season and "open" much earlier (I had to do this with the mesh cover to avoid algae blooms).
    If I didn't like the maintenance involved using a mesh cover, I think it would be even worse with no cover, at least in my situation.
    I'm guessing where you are the water stays cold enough all winter. Here can be pretty mild in the winter so water temp can fluctuate quite a bit, perhaps warming up enough for algae to start blooming, requiring regular testing, adding bleach to keep it in check. I'm other words, regular maint over the winter.
    Maybe one winter I'll get the guts to give it a try and see how it goes.
    PS - I agree, covers are a big PITA!
  1. New Pool Owner/Pool Cover Reel Recommendations
    By ntaulbee in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 03:18 PM
  2. Pump recommendations for 24' semi-inground pool
    By EricD in forum Pool Equipment & Operations
    Last Post: 06-05-2011, 09:10 PM
  3. AG cover recommendations
    By TimWillin2 in forum Pool Equipment & Operations
    Last Post: 06-09-2008, 04:47 PM
  4. Solar Cover Reel Recommendations
    By ToddLV in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2006, 03:40 PM
  5. Solar Cover and Reel Recommendations?
    By valentij in forum Pool Equipment & Operations
    Last Post: 04-15-2006, 03:34 PM
