Thread: pool specs
    Aug 2014
    Maryland
    Default pool specs
    inground pool / hoy tub
    27,000 gal
    gunite
    saltwater
    heat pump heater
    wanted to read up on the technical definition of alkalinity
    Default Re: pool specs
    Hi and welcome to the Pool Forum! There is a page on our sister website (www.poolsolutions.com) that may be helpful to you. Use this link to search with http://pool9.net/search/ and search for "what is alkalinity." You will find a page with FAQ about alkalinity that may give you the information that you are looking for.
    Hope this helps!
    (Until your registration is completed, you won't be able to see the rest of the forum or follow links while you are logged in. So, copy the link and paste it into a browser window after you first log out.)
  1. pool specs
    By lap-pool in forum --cleanup--
    Last Post: 08-12-2014, 07:21 PM
  2. Looking for Hayward pump specs
    By gpshemi in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2006, 06:07 PM
