Results 1 to 10 of 11
Thread: Intex Sand Filter
    Aug 2014
    Tennessee
    Default Intex Sand Filter
    Can someone tell me how to figure the MINIMUM flow rate of a sand pump filter? Trying to determine if we can place a skimmer on this pool & what type of vac we can use. It is a 16x32 Intex Ultra Frame.
    Default Re: Intex Sand Filter
    Minimum? Wouldn't that be Zero gpm?
    Aug 2014
    Tennessee
    What I need to know is this: I have an Intex SF70110 with a maximum flow rate of 2150gph, all the accessories I have looked for, side wall skimmer, vacuum, say the pump must have a minimum flow rate of 800gph. We have a 16x32 Intex Ultra Frame pool
    BigDave's Avatar
    It will be less than the rated 2150 because of losses in the tubing and filter. It should definitely be above 800gph. There's probably wiggle room in the 800gph rating as well but the manufacturer probably doesn't want customers with a 350gph pump complaining that the product works poorly.
    Aug 2014
    Tennessee
    Thank you very much for your response you gave me exactly the information I needed. Now just for fun can you give me a fairly easy way to clear the air out of the vacuum hose so the pump will work????? :}
  1. Intex saltwater with sand filter
    By bbranen in forum Intex-type Pool Setup & Operations
    Last Post: 05-08-2014, 07:52 AM
  2. Upgrading to Intex sand filter
    By DatsTray in forum Intex-type Pool Setup & Operations
    Last Post: 08-08-2012, 08:34 PM
  3. Intex Sand Filter - Just pooped in my pool!
    By KeggerTx in forum Pool Equipment & Operations
    Last Post: 09-13-2011, 01:58 PM
  4. best intex sand filter for 16x48 pool?
    By anikahmae in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 09:13 AM
  5. Upgrading an Intex pool to sand filter....
    By aylad in forum Above-Ground Pool Construction & Repair
    Last Post: 08-12-2010, 01:59 PM
