Thread: new to pools. pool guy has me confused
    Aug 2014
    IA
    Default Re: new to pools. pool guy has me confused
    ok I have some info I can provide. the pool is 15,000 gallons. we used htc algae guard 3x concentrate. listed is alkyl 15% alkyl 15% inert ingrediants 70%
    the chlorinating granules are 47.6% calcium hypo and 52% other. per you stated these are bad and we will not use these anymore
    the tablets are 99.7% trichloro s triazinetrione
    Quote Originally Posted by justin1795 View Post
    Ok, you'll need to re-run the test numbers with the HTH 6-way drop kit, if you have it.
    ASSUMING your numbers are correct (and that's an assumption), you should NOT use the Cal-Hypo powder anymore because it keeps raising your calcium level, and 400 is the upper limit.
    Do not use the "Algae Guard"--it will only make a bigger mess.
    One jug (121 ounces) of Clorox 8.25% bleach will add 5.2ppm of chlorine to your pool. A pound of Di-Chlor powder will about 4.8ppm of chlorine to your pool, and about 4.3ppm of CYA/stabilizer.
  1. new and confused about using bleach in pools
    By stargazingmommy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2013, 10:24 AM
  2. New pool is filling up now...so confused on what to do!
    By colleenebeans in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2013, 11:15 PM
  3. Strong Pools 33X56 and Confused
    By nathanc03 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2012, 01:53 PM
  4. Confused by Pool store analysis
    By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2006, 05:56 PM
  5. New Pool Install - Very confused
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 04-18-2006, 07:56 PM
