Thread: SR Smith diving board bolt washers/caps
    Aug 2014
    United States
    Default Re: SR Smith diving board bolt washers/caps
    If you're talking about what I think you are, you need to add a zero to that number. Diving board hardware kits are over $100, even for retailers. Go to your local pool store and grit your teeth.
    Aug 2014
    mass
    Thanks for the reply. I'm just looking for the plastic washer and cap that covers the bolt head. I've found them for $13.89 each plus $14.70 dollars shipping. I was hoping, I guess to no avail, someone might have found a less expensive location or substitute.
    Thanks again for the reply. I'll post if I come up with anything.
    Don
    Aug 2014
    mass
    Just found these for $20.00 + 5.00 shipping. The bolts are not stainless but its the plastic parts I needed.
    http://www.ebay.com/itm/131226542495...84.m1497.l2649
    Aug 2014
    United States
    Ah, gotcha.
  1. diving board replacement
    By rstarsdad in forum In-Ground Pool Construction and Repair
    Last Post: 08-12-2013, 03:14 PM
  2. Diving Board Resurface Kit?
    By DC912 in forum Pool Equipment & Operations
    Last Post: 09-15-2012, 05:02 PM
  3. Epoxy Bolt Kits for Diving Board Bases
    By tyandnikki in forum Pool Equipment & Operations
    Last Post: 07-28-2011, 11:56 AM
  4. Remove the diving board?
    By ChuckD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-26-2006, 01:18 PM
  5. Diving Board Purchase
    By stlouis123 in forum Pool Equipment & Operations
    Last Post: 07-04-2006, 05:02 PM
