Re: Setting up 12' pool at the end of the summer - chemicals?
One note of caution about the pool calculator website: With chlorine as a major exception, it's best to sneak up on your desired chem levels in the pool because in the real world things happen that the caculator wasn't designed to handle.
When you calculate an adjustment, dose half the calculated amount, let it mix and test again. If it still needs adjustment in the same direction, use half again as much and repeat. This test - adjust - test - adjust ... cycle will save you from the hassle of over adjust - then over adjust the other way - then back again - and on and on.
For chlorine, especially bleach, add what you need - if you go a little over, the sun will bring it down pretty quick.
