Results 1 to 9 of 9
Thread: CYA Level
    Jun 2014
    Florida
    Default CYA Level
    I came across the CYA test comments using 1/2 pool water and 1/2 water with no CYA. I have been interpreting the results using my test kit [Taylor K-2006C] to be 125 or so. Using the 1/2+1/2 method it read 90, so that means CYA @ 180. All else is checking out ok. Looks like I need to drain and refill? Any additional suggestions or comments.
    screened 23.2k gal rectangular 17 x 38 gunite IG pool, depth 4 - 8.5 ft, American Eclipse sand filter, new sand, Hayward EcoStar VS pump. PF=5
    Default Re: CYA Level
    It's kinda risky draining a pool completely for fear of it popping out of the ground if you have a high water table. Usually better to only do a partial drain and refill.
    Another option is to just run a HiC2 pool --- high chlorine/high CYA. You can read more about the CYA and chlorine relationship here:>
    http://pool9.net/cl-cya/
    If you do decide to run a HiC2 pool, no more trichlor or dichlor as both of them will continue to add more CYA.
    Hope this helps.
    Jun 2014
    Florida
    Ok thanks. I will raise the chlorine level and see how we like it. Draining is not a big issue, low water table. Will raise it up to 8.
    Jun 2014
    Florida
    Watermom
    So no more tabs [trichlor], use bleach to keep FC up and maintain other chemistry. No health concerns with HiC2 pool?
    No, its fine and won't hurt a thing. Lots of people run HiC2 pools on purpose. An advantage of doing so is that it typically allows you to test and add chlorine (bleach) less often. The only drawback is that if your pool gets algae, it takes very high shock levels to clear it but as long as you are diligent about keeping your chlorine between the minimum and maximum of the range in the chart I listed above, you shouldn't have algae.
    Jun 2014
    Florida
    I have read posts about High CYA causing some cloudiness, etc. Pool looks great during day and pretty good at nite. Notice a lot of particulates at night when light is on and especially near the light. High C2 pool with CYa levels at 150-180. Is is advisable to use a water clarifier, specifically Leslies "ultra bright" to remove some of whatever this is??CYA 150 ish, FC 9, CC 1..
    Thanks for commentary
  1. I can't seem to keep a FC level above 1.0.
    By reesie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2014, 10:32 PM
  2. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  3. Intex Ultraframe 12x24 How Level is Level?
    By DMDPT in forum Intex-type Pool Setup & Operations
    Last Post: 07-29-2012, 03:20 AM
  4. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  5. How level do I have to be?
    By tantor in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2011, 11:54 PM
