Absolutely don't know how to do that!
15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
Is there a valve for the "extra" line? If so, we can tell you how.
i was never told about an extra valve- was told not to worry about the extra hole…..I have 3 "T" valves. I turn off 2 when vacuuming.
(I probably need to review pool terminology)
When vacuuming, you leave on the skimmer valve. You apparently close the main drain. What changes when you close the third one?
As long as it has pool water flowing through it, I wouldn't worry about it.
So continue to keep the pool at shock level- 30- and see what happens to the CC.
btw: the skimmers again have a very thin line of sticky, greasy, black stuff around the waterline. I was going to wet a cloth with chlorine and wipe. Never had this before last Sunday.
The shock seems to be working, I wouldn't stop now. Like PoolDoc said - clean that goo off while you can.
