Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    Jul 2013
    Northern Illinois
    Default Re: Clear, but no chlorine???
    What BigDave said!!!! And do some research on the light issue. With no visible algae and high chlorine demand, it is worth considering. The demand is coming from somewhere... I was scared to death my first time. Afterwards I just laughed at myself because it was so easy. You can shut off the breaker if you're concerned about the electricity. Glad your Mom is better.
    Jul 2013
    Northern Illinois
    Just an aside here and sorry for hijacking you, MaryJo. BUT you are the man, BigDave for working so hard during Ben's hiatus. He is so incredible and we all owe him SO much. Thanks from me. Again, my apologies, MaryJo!
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    Just checking in. Last night (Sunday) at 9pm I added the jugs of chlorine to get FC to 30. This morning at 7:30 I tested (using diluted sample as you described- 5:1, results x6 and DPD reagent) and got FC=18. My FAS reagent comes in today so I can get more accurate results.
    I just added 3 jugs to get the FC back up to 30. My question is: how often do I check during the day?
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    BigDave's Avatar
    Check as soon as the FAS-DPD reagent comes in.
    Jul 2013
    Northern Illinois
    Then, as often as you can to keep it at shock level. (Ignore purple highlighting).
    Aug 2014
    Batavia, IL
    My reagent came in yesterday, and I tested throughout the day- tried to estimate testing times so that FC level never got below 25. Last night @ 11:00 the FC=33. this morning at 7:30 it was 22. Should I add more in the evening so that there is at least a 30FC level in the morning?
    You don't need to test and adjust your FC more than 3x day--Morning, mid-day, and after the sun passes in the evening. Morning and evening are the two most important tests.
    Do we know your CYA/stabilizer level? If it's 100ppm or more, you need to maintain an FC level of 25 or more until the algae is completely dead.
    Remember to run your filter 24/7, vacuum to waste, and brush the pool daily until you've won the battle.
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 07:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 04:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 11:01 AM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 11:30 AM
