I recommend that you bring the FC to shock level. At CYA 150ppm, 20% shock level is 30ppm FC. In 26K gallons it'll take 10 jugs (not jubs ) of 8.25% to get there from FC 0ppm. All at once. Pour the bleach around the pool so it's not concentrated in one place.
Keep the filter running 24/7. Keep FC at 30ppm until you lose less than 1 ppm FC overnight, you have 0 or nearly 0 CC and the pool is clear. Run the pump 24x7 while shocking. Leave the pool cover open if you can - some of the byproducts produced while shocking the pool may damage the cover.
