Thread: New user
    Aug 2014
    texas
    Default New user
    Found this forum while researching a pool problem & the bbb method.
    22,000 gallon IG gunite pool running a DE Hayward filter DE-4800 (48SQFT 96 GPM), Hayward Vari-flo multi-port valve 715XR60, Pump - Century Centurion 0-177215-04 1hp
    My pool is a mess and we are trying to decide what to do next. We were having an algae problem with our chemistry getting all off when we noticed after a backwash that our pool was still leaking out the backwash line. We looked it up and found the most common problem was the spider gasket. Sure enough the gasket was warped and torn. We researched it and replaced it. I'm pretty sure we did it correctly, (glued it down with silicone sealant from leslies pool supplies, ridge side up) but in the process the screws that held the top of the mpv on became badly stripped (were already a little stripped). We also noticed that afterwards the handle was hard to switch between settings. After getting it back together we tested it and it still leaks, we also found that it leaks in recirculate setting. So we can't get the mpv open now and we cant run it without losing considerable amounts of water. Other than completely replacing the mpv I am at a loss as to what todo. In the meantime my pool has gone from kind gross to full on bad. I'm afraid we may end up needing to drain it completely. Suggestions?
    Any ideas how to get the stripped screws off?
    Does it still sound like a spider gasket or something else?
    Can anyone direct me how to replace a mpv?
    Our pool details are: 22,000 gallon ingound gunite pool running a DE Hayward filter and using a Hayward Vari-flo multi-port valve. What we plan to replace it with if it is needed is a Hayward SP0715XR50 Pro Series Vari-Flo Control Valve (newer model of the same valve we already have).
    BigDave's Avatar
    Default Re: New user
    Quote Originally Posted by javaverses View Post
    Are the threads stripped or is the screw head damaged where the screwdriver turns it? There is a special tool called a screw extractor that can engage a damaged screw after drilling a small hole in it.
    Maybe the new spider gasket was damaged because you couldn't push the handle all the way down before turning it.
    Perhaps you can just replace the top of the valve and internals.
    Aug 2014
    texas
    The screw head is damaged so that a screwdriver can't get a grip on it. Thanks I will look into getting the screw extractor. I'll update as soon as we can get in and see what happened to the gasket and go from there.
  1. hello all. New user
    By TC213 in forum -- Subscriber Posts --
    Last Post: 06-11-2014, 10:45 PM
  2. New User Hello
    By Dena85 in forum --cleanup--
    Last Post: 09-13-2013, 01:51 PM
  3. hello everyone - new user
    By barcodeunit in forum General Interest
    Last Post: 08-12-2013, 11:08 PM
  4. New User
    By hazellee116 in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-13-2012, 04:18 PM
  5. New user looking for above ground pool reviews, ratings n user pics of pools
    By Piggiesinlove in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2011, 06:08 PM
