Thread: Kiddie pool advice
    Aug 2014
    Redding, CA
    Default Re: Kiddie pool advice
    I noticed that I also forgot to mention, this pool is under a very large patio and is never in direct sun. It gets a very small amount of sun on the outside vinyl side for about 30-45 mins in the late afternoon but that's it. I know this will allow the chlorine to last a lot longer without stabilizer.
    BigDave's Avatar
    Did you look at this page:http://www.poolsolutions.com/gd/kiddie-pool-care.html or the Super Simple Recipie page on PoolSolutions.com? The kiddie pool page is fine for 480 gallon pools.
    I seriously doubt the pump uses 1800 Watts - something's wrong with this number.
    I'd suggest you follow the kiddie pool plan referenced above. Dump and refill the pool monthly and when there's a fecal accident and when the water gets cloudy or a hint of green. Run the pump whenever no one's in the pool.
    Let us know how you plan to proceed and how the water looks.
    Aug 2014
    Redding, CA
    Yea, I thought 1800 watts sounded really high, but that's what's printed on the pump itself. I know that 300 GPH didn't sound big enough for that pool, I may still get a 1000 GPH just so I can run it less and have a better filter. I did read those two pages you referenced, I just wasn't sure the exact thing applied for 480 gallons. Also, the calculator seemed to be based on 5.25% bleach and all I can find now is 8.25%. Where would I get an accurate measure of the amount to start with or should I just use a test kit and just dump some in?
    BigDave's Avatar
    Just use 2/3 as much 8.25% bleach or 1Cup instead of 1.5Cup. If you buy a bigger pump, also buy the quality Filbur or Unicel cartridges referenced in the Super Simple recipie page. The standard filters for the little pool filter-pumps let lots of stuff through.
    Do get some bleach in the pool as soon as possible - you don't want to grow a swamp.
    Please also consider ordering a Taylor K-2006 testkit. Many small pool owners turn away from buying a ~$60 test kit but I can tell you that small pools get out of hand way faster than big pools.
    I need to write new SSR's (Super Simple Recipes) for both tiny pools like your, and for larger pools.
    However, you can modify the SSR (http://pool9.net/ssr/) for your situation:
    1. Drain and refill every 2 weeks. (On pools that small, it's the only way)
    2. Use dichlor to chlorinate. Use bleach only if you're out of dichlor. (This is covered in the SSR).
    3. Use borax to raise the pH; get a bottle of 'spa pH Minus' to lower the pH . . . if you need to do so. But don't mess with it if the pH is between 7 and 8.
    Otherwise, the SSR covers what you need to know. Do be careful: tiny pools are heavily 'fertilized' by the people 'goo' from you and your family. And though it's not extremely common, such pools can become 'growth chambers' for some pretty toxic and dangerous micro-organisms, even more than a large pool would.
    The ugly fact is that CARING for a tiny pool will cost several times as much each season, as BUYING such a pool costs.
    . . . membership updated.
  1. kiddie pool startup
    By rjherbst in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-09-2013, 12:59 AM
  2. Kiddie pool PH help
    By landbk in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-27-2012, 11:42 AM
  3. New small kiddie pool.
    By chadgreen in forum Above-Ground Pool Construction & Repair
    Last Post: 07-29-2011, 12:54 AM
  4. kiddie pool
    By jnkoh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-30-2011, 08:20 AM
  5. Kiddie pool leak
    By jwr19 in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2006, 12:33 PM
