Thread: Gorilla Floor Padding
    Aug 2014
    colorado
    Default Gorilla Floor Padding
    Well my question is a simple one to start with can I use gorilla floor padding and sand under a 18*48 ultra frame pool with paver under each leg. I'm glad I found you guy I have been having problem with my pool sitting on pea gravel and being unlevel
    BigDave's Avatar
    Default Re: Gorilla Floor Padding
    Sounds like a pretty good plan. Be sure the sand / gravel won't wash out and that the pavers are set on solid ground - not sand or gravel.
  1. Gorilla Pad
    By acarstens in forum --cleanup--
    Last Post: 05-20-2013, 12:17 PM
  2. Padding w/ an expandable liner?
    By JJD5877 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-22-2011, 05:19 AM
  3. Gorilla Pad
    By cooper in forum In-Ground Pool Construction and Repair
    Last Post: 04-26-2011, 01:00 AM
  4. Gorilla Pad -- experiences?
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 05-21-2007, 12:41 AM
  5. can foam be used for padding?
    By mlt298 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-04-2006, 12:16 PM
