Thread: Need advice in regards to thickness of foam flooring
    Default Re: Need advice in regards to thickness of foam flooring
    Hi Dennis, Dennis here. For your purpose the cheaper of the two would be fine. I agree with the instructions you found, 2" of sand or 1 1/2" foam. 1" works if you have a smooth hard packed sand base to install it over. In your situation the 1 1/2" will be perfect.
    1/2" should not make much difference in liner fit, you should be just fine not having a 2" base. I would much prefer to have the liner a little snug than have too much liner.
    I spent a whole summer installing 48" beaded liners into 52" wall pools simply because they fit better. The hot Arizona sun is very nice for getting a little stretch out of a vinyl liner. Make use of some overhead sunshine and the whole job becomes easier.
    A beaded liner installed correctly in the bead should not pull out, especially with the help of a little sunshine.
    Later, Dennis
    DennisP is offline Registered+ Thread Analyst DennisP 0
    Jul 2014
    New Berlin, WI
    Thank you sir!
    That was exactly the kind of info I was looking for...
    After being delayed almost a month and a half from my original timetable to get this yard project done I just want everything to go as smoothly as possible...
  1. Does the thickness of solar cover matter
    By rdefino in forum Pool Equipment & Operations
    Last Post: 04-30-2014, 09:54 PM
  2. Foam pad?
    By Maureenmc in forum --cleanup--
    Last Post: 06-21-2013, 12:28 AM
  3. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  4. Oh My.. foam everywhere!
    By tamil in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 11:09 PM
  5. IG Liner Thickness
    By pmdelage in forum In-Ground Pool Construction and Repair
    Last Post: 04-02-2006, 01:24 AM
