New owner of first pool: just completed, inground, 17,000 gal, Pebble Sheen finish, dark color. Fill-up complete 6/8, pump and filter operational late in the day 6/8. Will have SWG in a few weeks. Have ordered Ben's kit but have not yet received. All tests done by Wal-Mart HTH drop tests and some done by Leslie's, hoping to check my results. Filter/pump on 24/7. Absolutely no chemicals whatsoever added at start-up.
All Pebble materials indicate I should get pH and alkalinity in balance prior to chlorination.
My tests 6/9: Total Cl 2.0 (test kit only does total)
pH 8.2+
TA 90
Ca hardness 90 (really this low??)
Leslie's test 6/9: Free Cl 1.5
Total Cl 3.0
pH 8.0+
TA 50
No other tests offered, these were all by drops
My test 6/10: Total Cl 1.5
pH 8.2+
TA 80
Water temps are 82 in early AM, 86 at mid-afternoon.
Leslie's recommended adding 15# of Alk Up, even tho it would up my already-high pH, and handling the pH after that. I wasn't convinced so I did nothing.
After today's test, I have more faith in my TA readings than theirs, so am planning on adding a mere 2c of muriatic acid to drop my pH just .2 tonight. Basically, I'm trying to guage my pool's response, so am not trying to correct my pH all at once. I plan on testing daily and will do another calcium test and the first stabilizer test tomorrow.
Water looks very clear, pebbles on bottom highly visible. Water has a greenish cast from the side, but I've heard of lots of Pebble customers having a green-ish color to the finish/water that eventually changes to the true color. We also have a good reflection of some very green trees that could be affecting my impression of water color.
Am I on the right track? I'm concerned about having enough chlorine to keep my pool clean too. Should I be adding bleach?
Thanks for the help.
DD
